AR-M355N Continually Codes with C1-00
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Error Code] AR-M355N Continually Codes with C1-00
    The customer recently indicated that if the fax unit is off, it runs fine, however if turned back on, boom C1-00 will follow shortly thereafter.
    Has anyone seen this or have any ideas on how to permanently fix this? Thanks in advance!
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • igi
    • 1507
    Re: AR-M355N Continually Codes with C1-00
    hi try high-voltage pwb,and how is the contacts/electrodes
    on the back frame
