Is main difference only the feeder 4100N vs. 4101N ?
  • CCS
    • 266
    What is the main difference between the MX-4100N and the MX-4101N ? Is it only the reversing feeder vs. the duplex single pass feeder or is there something else ?
    Looks like they were both released in Jan. 2009.
    In your opinion, which is the better box ?
  • rgcs1
    Systems Intergrator
    • 69
    Re: Is main difference only the feeder 4100N vs. 4101N ?
    Mainly the same machine but as you said MX4100 comes with a R.S.D.F and the 4140 comes with the D.S.P.F
    • CCS
      • 266
      OK, thanks
      Is one doc-feeder better or worse than the other, any issues?
      • rgcs1
        Systems Intergrator
        • 69
        not the case of one better than the other.....
        One is a reversing single pass feeder (RSPF) 100 sheet feeder, scans 1 page at a time at 50 originals per minute.
        The other is a Duplex single pass feeder (RSPF) 150 sheet feeder, scans both sides at 70 originals per minute.
        Hope this helps......
