Custom paper size on MX4101 for cassette
  • bdcrandall13
    • Sep 2010
    • 235
    I have a customer with an MX4141N that needs to be able to run 8 1/2" x 15" paper in duplex through a paper drawer. Out of the box you cannot set the cassettes to a custom paper size. The manual says that custom sizes can be used in trays 1 and 2 through soft switches. Does anyone know if this is true and what switch it might be?
  • bilyahn
    • Dec 2006
    • 1467
    Re: Custom paper size on MX4101 for cassette
    I will need to verify this at work but I'm pretty sure you can set manual paper sizes on this unit in system setting tray settings. Pretty straight forward all Sharps have done this for awhile but I will look at our unit at the shop.
    Good luck.
    Bil
    • bdcrandall13
      • Sep 2010
      • 235
      Good luck.
      Bil
      There is no option in tray settings on this model for trays 1-4. In the service manual specs it says it can be accomplished through soft switches. Although it has an asterisk with it that has the letter J by it. I'm hoping it doesn't mean Japan only or something.
      • bilyahn
        • Dec 2006
        • 1467
        Okay, quick question. Do you have a 4101 or is this the one you have listed in the body of your message 4141?
        • bdcrandall13
          • Sep 2010
          • 235
          Sorry, I was working on a 4101 this morning and confused myself... This post is in regards to the MX4141N.
