Sharp MX 2700n. Copies will not be offset.
  • Jack79
    • Jul 2014
    • 312
    Hello
    On the top of the screen (on the black color panel) I have following information
    Ready to scan for copy.
    What can I do to clear this information "Copies will not be offset"?
    Copier works fine. It had RBX1 tray installed before which I removed but probably it is not link to this issue.
  • sharphead
    • Aug 2009
    • 285
    Re: Sharp MX 2700n. Copies will not be offset.
    Not quite sure what you mean jack, if it had an rbx1 then it had a fnx2. Is the finisher completely disconnected. I think the finisher couldn't offset paper under a certain size
    • Jack79
      • Jul 2014
      • 312
      This Sharp came to my friend without finisher. It had RBX1 installed so we removed it because of L4-11 error. After that error disappear and we could use the copier. I am not sure if finisher has been disconnected completely (we do not have finisher). I think we should setup something but we do not know what?.
      • faxman28
        • 436
        Originally posted by Jack79
        Hello
        that is normal message, the offset function default is probably set to off. Take 2 pages put them in doc feed, make 3 copies, are each set being offset.
        • Ceechtay
          • Sep 2011
          • 157
          The "Copies will not be offset" message is normal and simply means that the copier's settings are not set to offset. If you want to change the default copy settings to offset copies (which is the factory default), simply do this at the copier:
          System Settings button
          Admin Password -> admin is the default password
          Page down to Copy Settings
          Initial Status Settings
          Page down to Output
          Place a checkmark in the box next to Offset
          Hit a bunch of OKs and exit on out
          This will get rid of your message and your copies will now offset by default.
          • Jack79
            • Jul 2014
            • 312
            Page down to Output
            I was looking to Copy Settings but didn't go to Initial Status Settings.
            Thanks a lot.
            Problem solved.
            • bdcrandall13
              • Sep 2010
              • 236
              Thanks a lot.
              Problem solved.
              Just FYI... If you are using mixed size original then offset must be turned off. We have multiple customers that have mixed size original turned on by default. The only bad part about that is that offset is then disabled by default as well. You must go in to special modes and turn off mixed size original to be able to offset.
              • Jack79
                • Jul 2014
                • 312
                the option mixed size original is turned off.
                Thanks for this information.
