error cod sharp
  • decacazza
    • Apr 2014
    • 16
    [Error Code] error cod sharp
    Good day to all I have a problem on a sharp mx-2301
    with error code C1-10 what can it be? thanks for the help
  • ntbann
    • Jan 2012
    • 628
    Re: error cod sharp
    The manual says monochrome main charge error. 1 check black corona, 2 check the contact springs on HV PWB, 3 replace HV PWB.
    • decacazza
      • Apr 2014
      • 16
      Re: error cod sharp
      thank's a lot
      • mojtabamrt
        • Jun 2019
        • 3
        Re: error cod sharp
        hi guys
        i have same problem to sharp mx-2301n
        not ready to print
        in display write a message : Version Check IcuM:ROM UNUSUAL
        pls help me soon guys
        thanks alot
        good job
        mojtabamrt
          Re: error cod sharp
          Originally posted by mojtabamrt
          hi guys
          not ready to print
          thanks alot
          good job
          mojtabamrt
          1) ok grave robber .. dead thread...
          2) clearly you are NOT a tech with the comment posted
          3) might want to start your own thread.. but seeing you are an end user.. you should hire a certified tech.
