MX3501N: FK2 code
  • RandyW
    • Jan 2013
    • 213
    MX3501N: FK2 code
    had someone call us with 1 of these copiers and they say it has a FK2 code. Does the machine stop at a certain point with that like a web roller?
    I got a copy of the service manual and see FK1 but not FK2. FK1 says:
    FK1 The fusing unit print counter reaches 200,000
    sheets.
    Fusing Sub Heat Roller counter? for FK2?
    thanks.
  • ZOOTECH
    Senior member of CRS
    • 3374
    Re: MX3501N: FK2 code
    sheets.
    thanks.
    Count for sub heat roller is 150k sheets. By default, print jobs are enabled.
    • Ben Around
      • Apr 2012
      • 151
      sheets.
      thanks.
      FK1 THE FUSING UPPER AND LOWER HEAT ROLLER PRINT COUNTER REACHES 300,000 SHEETS
      FK2 THE FUSING SUB HEAT ROLLER PRINT COUNTER REACHES 150,000 SHEETS
      FK3
      • laitang
        • Nov 2012
        • 627
        FK2 The fusing sub heat roller print counter reaches 150,000 sheets.
        After completion of the maintenance, execute SIM 24-4 (Fusing unit counters (number of the fusing unit print counter, days of use of the fusing unit) clear).
        • RandyW
          • Jan 2013
          • 213
          thanks for the info.
          was the FK2 added in the book later or something?
          This particular customer picked up the copier when they acquired another company...going to go by and see what all it may need.
          • harleyrider
            • Oct 2011
            • 348
            In my service manual it is on page 9-15
            • Ben Around
              • Apr 2012
              • 151
              Page 9-15 in my tech manual as well.
