I have a MX-2300 that has no display or lights on Ops panel but the fans are running. The fans may take 30 seconds to kick on at startup but never shut off. The fuser does not heat up.
I swapped memory from DIMM2 to DIMM3, per bulletin, Same issue. I swapped AC and DC PWB out, same issue.
All fuses on AC and DC PWB have continuity. I have measured 3V, 5V, 12V and 24 V on mother and PCU PWB. I have measured 24V at the SCN PWB and LVPS PWBs fuse.
I have unplugged all the motors and fans that I have seen on the back of the machine, including the ones behind the MFP and PCU PWBs.
Thank you for any help.
