Not printing correctly
  • cfragassi
    • May 2012
    • 9
    [Misc] Not printing correctly
    I have a Sharp MX-5001N using Post Script. When printing in MS Office they try to print a watermark of "DRAFT" on the document it prints out with 5 blocks instead of the word draft. On a MX2600 it prints fine. Please help.
  • bbiggers
    Re: Not printing correctly
    Are you using the right driver for the MX5001N? Using post script? Try PCL6?
    • cfragassi
      • May 2012
      • 9
      Yes using the right driver. Downloaded from Sharp. They use post script for better printing performance.
      • mojorolla
        The Wolf
        • 2627
        Try reloading the watermark firmware using SIM 49-5.
        • MFPs R Now PCs
          MFP Tech & I.T. Manager
          • Jul 2011
          • 156
          Postscript does not give you better printing performance if you are looking for SPEED of Font-data/transfer when printing. One of the big differences is how PS & PCL handle the fonts. Try changing the setting in the driver to "downloading" the font instead of using "resident" fonts. It is usually in PREFERENCES/ADVANCED/FONTS. If not there, hunt around a little. I'll tell ya, I HAVE SOLVED SO MANY GARBAGE CHARACTER PRINTING ISSUES BY DOWNLOADING INSTEAD OF ALLOWING RESIDENT FONTS. Good Luck!
          P.S. Downloading fonts can increase the network traffic/transmission times though.
          It does not matter how slowly you go as long as you do not stop. –Confucius
          • cfragassi
            • May 2012
            • 9
            Placed driver in download but still no help.
            • ntbann
              • Jan 2012
              • 628
              What version of microsoft word? Had this happen with old version word on a new MX4140
              • cfragassi
                • May 2012
                • 9
                Using word 2010. I fixed the problem. They had transparency at 70%. I changed it to 0 as per microsoft and everything is fine.
