MX 3110 ADF calibration sheet
  • jrob416
    • May 2011
    • 112
    [Misc] MX 3110 ADF calibration sheet
    I have been told that there is a calibration sheet available for adjustments to the ADF on the MX 3110. If this is so, how would one go about acquiring said sheet? Is this something that can be printed by the machine itself? Does this have to be purchased from a supplier? Inquiring minds would like to know. Thanks in advance for any input on this matter.
  • MHeon71
    • Oct 2008
    • 489
    Re: MX 3110 ADF calibration sheet
    I do not believe so. I base my answer off the Adjustment and Settings section of the manual. There is no adjustment that I see that uses a special chart.
    If you were to go that section of the MX-M503N, you would see a special chart in adjustment 5, I believe.
    • bilyahn
      • Dec 2006
      • 1470
      It's adjustment 4 in the SM starting on page 4-12 and the machine prints out the adjustment pattern. Makes it nice and easy, there are several different adjustments in this section but the SPF (RSPF) is one of them. It's not a "special" calibration sheet or anything like that. This has been available for a few years now on color and b/w units.
      Good luck.
      Bil
