MX-M260 blank prints
  • Jaws
    • Oct 2007
    • 236
    Printing out blank prints. It will scan to a computer and show an image. No error code at the moment. It did show a laser error code in the history so I swapped the laser but it did not help. Also took the laser and put it in an ARM257 and it did make a print. Today I tried a new power supply but it did not fix the problem. I guess it is going to be the mother board (MCU) I just don't have one to try at the moment.
    Any suggestions. We are busier than ever down here in the gulf coast region.
  • laitang
    • Nov 2012
    • 627
    Re: MX-M260 blank prints
    Did you check High voltage PWB?
    • Jaws
      • Oct 2007
      • 236
      I will check it tomorrow, thanks.
      • oldrn
        • 166
        Did you try looking at the drum after interrupting the print cycle to see if there is any toner being transferred to the drum?
        • Jaws
          • Oct 2007
          • 236
          Turned out to be the high voltage power supply. thanks Oldrn.
