MX m550 n Powers off and on
  • pontiac
    • 420
    Haven't seen this problem before, when copier is receiving print data copier powers off then on and will repeat until network cable is disconnected. I replaced network cable, complete control pcb and nic card and tried different network ports in office and still have the same problem no change. other connected equipment work fine. Thanks everyone.
  • ZOOTECH
    Senior member of CRS
    • 3374
    Re: MX m550 n Powers off and on
    We have been disabling WSD in Port Control of the Security Settings; not sure if this has completely stopped the powering off/on though.
    • pontiac
      • 420
      ZOOTECH THANKS FOR REPLY WHEN I MENTIONED YOUR SUGGESTION TO OUR IT TECH HE INSTANTLY SAID CONFLICTING IP ADDRESS NUMBERS. GAVE CUSTOMER IT DEPT. INFO AND THEY ARE PRINTING AGAIN. ps....WE HAVE HAD THIS IP ISSUE BEFORE WITH OUR OTHER BRANDS AND NEVER HAVE THEY SHUT DOWN LIKE THIS. Thanks again ZOOTECH
      • lky1978
        • Mar 2009
        • 476
        nothing wrong with the machine.
        Go to every computer , cancel all print job that pending. Will solve the reboot problem.
        • draph
          • 132
          Good call Iky. For some reason I'm seeing it all the time recently.
