MX-C311 E7-28
  • DeanG
    • Jul 2014
    • 11
    [Error Code] MX-C311 E7-28
    Hi everyone,
    I am working on a mx-c311 with an E7-28 code. The book says it is a connection problem between the LSU and PCU. I checked the connection, which was fine, and replaced both the LSU and PCU but I still have the code. Any suggestions?
    Thanks,
    Dean
  • rainmaker
    • Jul 2011
    • 77
    Re: MX-C311 E7-28
    noticed in the service manual that the LSU mother board could cause it as well as the pcu and lsu you already replaced.So i take it as soon as you power on it goes into the error?
    • DeanG
      • Jul 2014
      • 11
      Re: MX-C311 E7-28
      Yes, I get the code as soon as power is turned on. I replaced the LSU board when I replaced the unit.
      • rainmaker
        • Jul 2011
        • 77
        Re: MX-C311 E7-28
        just checking here to help you out.So you replaced the LSU part#DUNT-8109FCZZ,the PCU part # CPWBX1838FC32,ans the LSU mother PWB part #CPWBX1837DS51?
        Did it happen on its own? The error code.The only thing i could suggest is a wiring issue maybe a pinched wire
        • dasbrun
          • Jun 2014
          • 23
          Re: MX-C311 E7-28
          Try clipping all the zip ties on all the wires involved. Used to work on Canon's a lot and that was a common cause of weird issues, the zip ties are cinched down too tight and after time can cause all kinds of weird issues.
