MX-M450N constantly rebooting
  • MHeon71
    • Oct 2008
    • 489
    I have an MX-M450N that is constantly rebooting, but only when plugged into customers network.
    Unplugged from network and plugged directly to my laptop, the machine does not reboot.
    I have flashed firmware and I tried a new MFP PWB, new main flash rom and boot rom. I did not try to plug into a new port at the clients, ran out of time.
    Any help would be appreciated.
  • Josh93
    • Jul 2014
    • 47
    Re: MX-M450N constantly rebooting
    Could be a bad print job, confuses the machine and causes a reboot, I think there was a thread on here about a similar issue.
    Also conflicting IP?
    Here- http://www.copytechnet.com/forums/sh...owers-off.html
    • ntbann
      • Jan 2012
      • 628
      Bad PDF print job. Seen this a few times.
      • MHeon71
        • Oct 2008
        • 489
        Thanks for the help, you were both correct. A bad print job. I also checked for an IP conflict, which checked out fine.
        • MdangerP
          • Sep 2014
          • 45
          There is a website zillow.com that real estate people are printing from that has been consistently causing the same problem for us. Just a heads up for future reference.
          • Akitu
            Legendary Frost Spec Tech
            • Oct 2010
            • 2595
            Tell your customers to save the file they're trying to print locally first, instead of just printing from the web browser. The local print files will work a whole lot better...
            • Sharptech0892
              • Aug 2011
              • 79
              Switching to chrome fix are issue with that, using ie it happened all the time.
              • jp74msj55
                • Oct 2014
                • 151
                Had same problem, clear all print jobs in que at work stations and this is what fixed mine. Must have had corrupt file or web page.
                • colgrimes
                  • May 2012
                  • 64
                  Typical Microsoft.
                  CopierCollin.com
                  Hybrid Honest Sales/IT
                  • coopers1305
                    • Nov 2014
                    • 49
                    Power over Ethernet not wired correctly made one of my MXM350's do the same thing.
                    • DINGO
                      • 661
                      Hi
                      Sometimes hapened, i already saw a few times This.
                      And, as you said, unpluged the costumer network, and lluged at your laptop , works fine, so something is wrong in the network, may be first search a bad print job.
                      Delete all print jobs, or go to the print queue, and delete one each time, you found the bad job,
                      • Foxhound
                        • Mar 2014
                        • 33
                        Common issue. Check print queue on all pc's or server delete all print jobs. You may also need to restart print spooler. if you see a job on the server ask the customer who may have sent it. Almost always a corrupt print job or corrupt html based pdf.
