I have a machine that is depositing what seems like black toner on the guides above the fuser unit, both the left and right ones. It seems that it is only an inch or two wide right in the center. It is causing paper to jam there frequently. Recently tried to fix it with a new black drum unit and developer unit to no avail. There is a fairly new primary transfer in the machine. Copy quality is O.K. It seems like there is so much toner on the guides that I should be able to see where it's comming from but it's not obvious. Not showing up on the fuser rollers either. Any ideas would be appreciated.
