Sharp AR208 gray in non image area
  • bradallcopy
    • Oct 2014
    • 5
    I have a Sharp AR208D that is gray in the non-image area. You can see the test pattern also. It looks good, just gray where it should be white. If I do a internal test print the grid pattern comes out clean and looks good.. Only if I scan off the glass or adf does this happen. I first replaced the scanner assembly, but problem is still the same. I have order a new main pcb and ribbon, but haven't made it back to install them. Any suggestions what might be causing this?
  • draph
    • 132
    Re: Sharp AR208 gray in non image area
    What happens if you adjust the exposure?
    • bradallcopy
      • Oct 2014
      • 5
      Gets a little lighter. But still gray in non-image areas.
      • ntbann
        • Jan 2012
        • 628
        Did you run a 63-1?
        • bradallcopy
          • Oct 2014
          • 5
          I am thinking a did that adj. Shading adj. But just to be sure when I go back I will try it again before I install main board. Just trying understand why it would change all of a sudden. Working and then after weekend customer said it started.
          • harleyrider
            • Oct 2011
            • 348
            OEM toner?
            • bradallcopy
              • Oct 2014
              • 5
              Replace main pcb. All is well. Thanks for all you great suggestions!
