ERROR[936]: Scanning feature is not enabled.
  • hamada_ce
    • Jul 2025
    how to fix the
    Sharp ar-m258
    Image Send Management
  • MHeon71
    • Oct 2008
    • 489
    Re: ERROR[936]: Scanning feature is not enabled.
    Do you need to purhase the network expansion kit. Check specs for that machine and if it does, check product keys in system settings to see if it is activated.
    • ntbann
      • Jan 2012
      • 628
      MX-NSX1 not installed? Check System settings, Product key to see if it took the license number.
      • hamada_ce
        i have serial number only
        How to tell product key
        • MHeon71
          • Oct 2008
          • 489
          You have to go into system settings to check to see if it is activated. You will find it under product keys. If it is not activated, you will have to purchase MX-NSX1 and that would have the information needed to preceded.
          • ntbann
            • Jan 2012
            • 628
            Or print out a 22-6. That will show if it is installed also.
