A0-15 mx5001n with data security kit MX-FR11U
  • ohightower
    • Aug 2014
    • 33
    [Error Code] A0-15 mx5001n with data security kit MX-FR11U
    I'm stuck I talked with sharp hotline they couldn't help. I tried to swap of the mfp because sharp said it was bad when trying to scan to network folder. Couldn't get the other MFP board to work so I put back in the original one now I cant do nothing with the machine just popping up with A0-15 error. I tried to put the MX-FR11U chips back in and try to update the firmware and it says data error!!! The machine worked fine before I tried to switch the MFP board.
  • mojorolla
    The Wolf
    • 2627
    Re: A0-15 mx5001n with data security kit MX-FR11U
    Did you move the eeprom form the original MFP board to the new MFP board?
    You can also look at the 22-6 printout. Look at the scan soft switches. When changing boards without changing the eeproms, the scan switches will sometimes set themselves all to "1". This usually happens with 2 codes: A0-15 and AO-22.
    • ohightower
      • Aug 2014
      • 33
      I figured it out i had to put the mx-fr11u security chips back in and had to down load the emergency firmware then i flashed the lasted firmware im guess once your have the security kit installed you cant even change the rom chips or the mfp but everythings back working normal now thanks
      • ZOOTECH
        Senior member of CRS
        • 3375
        Thank you for the update - the security option, once installed, limits what can be done. Was the emergency firmware a download or the firmware renamed (emupdate...)?
        • ohightower
          • Aug 2014
          • 33
          It was a download off sharp idnc site under security kit firmware downloads emupdate was its own file then i used 49-1 to update to the regular security firmware
