Help Blank Copies
  • drbob101
    • Nov 2014
    • 15
    Help Blank Copies
    I bought a new SHarp168d online. It has never been used. It had he protective coverings, etc . on it
    I got a new towner. No error codes and all seems well but I have blank copies.
    Ay ideas?
    Thank you
  • faxman28
    • 435
    Re: Help Blank Copies
    probably needs developer, AR168d does not come with developer as these are normally setup by tech. did copier come with a bag of AR152nd developer? , also if you put doc in feeder on top it goes in face up.
    • drbob101
      • Nov 2014
      • 15
      No it didn't come with developer. I have the user manual for it. I don't see anything about developer? Where would that go?
      The is has lid on top. Doc goes face down. Anyway, I have treid it both ways as that's what the user manual says for blan copies.
      • drbob101
        • Nov 2014
        • 15
        Sharp Copier Developer Installation for Sharp AR-208, AR-M257, MX-M200D, MX-M260 copiers
        Great. I found this online. It appears you are right about the developer. It specifically says in there that you must add developer before toner. I inserted the toner cartridge and turned on the machine and tried copies. DId i screw it up now?
        • ZOOTECH
          Senior member of CRS
          • 3375
          Depends on how long you ran it - before you add the developer, empty the toner from the DV unit.
          • drbob101
            • Nov 2014
            • 15
            I tried maybe 8 copies total.
            What is the DV unit? Sorry for the amateur question.
            • ZOOTECH
              • 3375
              That is where the developer is added - it might have toner in it now because you powered on with toner cartridge installed.
              Follow the instructions from your post above.
              • drbob101
                • Nov 2014
                • 15
                Thank you very much for your help. I ordered some developer for delivery tomorrow and I will follow those instructions and hopefully that is it.
                Very much appreciate the guidance.
                • mojorolla
                  The Wolf
                  • 2627
                  For some reason, this image just fluttered through my brain...
                  • drbob101
                    • Nov 2014
                    • 15
                    Developer was delivered today and that link described the process and I got it loaded an Voila! Copies.
                    Thank you for your help!!!
