ar160
+ More Options
Posts
  • T911
    • Jun 2007
    • 628
    ar160
    When refilling toner CTG do I need to also change developer. Do I need to calibrate developer if it needs to be changed and is there a reset to get rid of the toner lite. Thx
  • amazed
    • 17
    Re: ar160
    Developer should be replaced every 50 000 copies,
    If the toner sign is blinking - simply add a toner.
    if it is lit - you should change toner chip, or replace cartridge.
    • harleyrider
      • Oct 2011
      • 348
      Re: ar160
      We don't have any of those in the field anymore. They had a bottle of toner with a flexible hose to refill cartridge every 15K. Developer was 15 K also. No reset just change dv and toner and seal and swap out unit if I remember correctly.
      • T911
        • Jun 2007
        • 628
        Re: ar160
        Yeh this one is an older one and I forgot too. Thx
