Has anyone had this problem. I have a sharp MX-B201d copier where the spf doesn't feed paper in
and the machine makes the noise for the scanner moving but the spf motor does not turn and the document does
not move. When I do the spf aging test (test command 2 sub 2 the motor moves and everything works.Not sure what
to do.
to do.
