Mojos Fix FN15/16 : F1-03
  • mojorolla
    The Wolf
    • 2605
    I have seen this a few times; had one yesterday so I took a few pictures. This is a FN16 finisher with an immediate F1-03 error at power up. The swing gate opens and stays open.
    The rear pivot point for the swing gate pops out, causing the actuator to miss 1 of the switches. This is a pic of the rear pivot point, main control pwb is removed:
    If you remove the upper exit finisher cover, you can access the double switch:
    One of the switch arms gets on top of the actuator switch arm jumped.jpg.....instead of behind it switch arm normal.jpg
    Re-seat the rear pivot, check the switch arms, good to go.
    Hope it helps.
  • Jhonjon
    • Sep 2013
    • 208
    Re: Mojos Fix FN15/16 : F1-03
    Thanks' for sharing...
