Update Firmware of MFP with Data Security Kit Problems
  • redserv
    • May 2010
    • 307
    Hello Guys
    I have a Problem with a MXM363N MFP,I attempted to update the Firmware of the MFP that has a MX-FR14U Data Security Kit,I am not sure what the Problem is but every time i try to do the update I get "Mismatch Error" I know that the Firmware works as i tried it on another MFP Without the Data security Kit,I suspect that because the data security kit is in the MFP that may be why the it wont update,Unfortunately I dont even have the original roms that came with the MFP, so I am stump, can someone assist?Thanks in advance.
  • spanky
    • Sep 2012
    • 468
    Re: Update Firmware of MFP with Data Security Kit Problems
    You must update with the firmware for the data security kit not the MFP.
    • bilyahn
      • Dec 2006
      • 1468
      spanky is correct. If you used this firmware on a Non DSK machine and it worked fine then it will not work for a DSK machine. Totally different ROMs and firmware!
      Good luck.
      Bil
      • mbcruzin
        • Aug 2013
        • 142
        Yep I did the same thing. Down load the newest DSK firmware and install it under your preferred method. You should be good.
        Happy Thanksgiving
        Kevin
        • redserv
          • May 2010
          • 307
          thank you guys for all the feedback really appreciate it.
          • redserv
            • May 2010
            • 307
            Hi again guys, I cant seem to find the MX-FR14U firmware on sharp service website can someone help please maybe with a link the MFP is MXM363N with DSK MX-FR14U.thanks in advance.
            • bilyahn
              • Dec 2006
              • 1468
              It's there under the data security kit portion of firmware updates. It's from 2012 and the file name is:
              Jupiter3_DSK_Conbi_0303jci0_B.sfu
              About 35 Mb in size.
              • mbcruzin
                • Aug 2013
                • 142
                I'll Leave this up for a few weeks.
                Its ready to be loaded on a thumb drive no unzipping required.
                Enjoy
                • redserv
                  • May 2010
                  • 307
                  thank you very much guys for all your assistance really appreciate the help :P
