MX 4112 with MX-FX11
  • mabro1974
    • Feb 2013
    • 39
    Hi guys i have a MX4112 and i have tried to fit a fax kit to it (MX-FX11) and when the machine powers up within a few minutes it throws up a F6-00 error.
    I have checked all connections , reseated all memory dimms , tried 3 different faxes , re-initialised it and and updated firmware.
    Any other ideas before ordering new MFP board.
  • laitang
    • Nov 2012
    • 627
    Re: MX 4112 with MX-FX11
    Destination setting
    1) Enter the SIM26-6 mode.
    2) Check to confirm that the destination setting of the machine matches the specifications of the FAX destination. If not, the FAX may not function properly
    After connection, perform the setting of “External telephone connection" of the system setting (administrator).
    • mabro1974
      • Feb 2013
      • 39
      Originally posted by laitang
      Destination setting
      Hi there ,
      destination is set ok, where do i find " external telephone connection " within system settings
      • laitang
        • Nov 2012
        • 627
        F6-00 Detail:
        MFPC PWB - FAX communication trouble
        Posible cause:
        Case 1 FAX control PWB trouble.
        Case 2 FAX control PWB - MFPC PWB connector and harness trouble
        Case 3 FAX control PWB - Mother board connector and harness trouble
        Case 4 FAX control PWB ROM trouble / ROM pin breakage
        • mojorolla
          The Wolf
          • 2622
          The new MFP boards have 2 plugs for fax kits as overseas models can support dual fax kits.
          Make sure the option is plugged into FAX 1 on the MFP board.
          • ZOOTECH
            Senior member of CRS
            • 3375
            Yep, just have to follow the install manual.
