MX2616N PROBLEM
  • DAKOTADAN
    • Jan 2011
    • 61
    MX2616N PROBLEM
    Could use some help on this one, I have a MX2616N that started offsetting the colors, especially the magenta, as my 61-4 and 64-5 show in the examples. When I run 50-22 I get a Data Sub_F_Head 32 error. Machine prints and copies OK in black. I changed, out the magenta drum, dv unit, main transfer and secondary belts, laser unit,
    reflashed firmware to 0700G2.
    I reseated Sim, and IC on MFP board. Still get bad color prints and copies. My next thought is bad memory or mother board.
    Any help is appreciated. Thanks Dan.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: MX2616N PROBLEM
    Try running TC 50-20 first, then 50-22.
    • faxman28
      • 436
      Re: MX2616N PROBLEM
      TT-100314_1 , set 50-20 A to I to 100 then redo 50-22, TT-100314_2 new sim 61 codes for uneven color registration, doesn't list 2616n in bulletin but maybe with latest firmware is available ?
      • DAKOTADAN
        • Jan 2011
        • 61
        Re: MX2616N PROBLEM
        Thanks Zootech, you were right on, I had try to do 50-20 early on the call, but I only changed the magenta offset values to their defaults, and let the other magenta settings as they were. Now I set all the magenta values on 50-20 to default, then I could do 50-22 and get it to say OK by adjusting the screw. Next time I see this should I set all
        the settings on 50-20 to their defaults? Or just the color that is giving errors and bad prints? Thanks for all the replys I got. Dan
        • ZOOTECH
          • 3375
          Re: MX2616N PROBLEM
          It wouldn't hurt to set them all to defaults as the TT mentioned by faxman28, TC 50-22 will get you to the proper adjustments. As an aside, I try to get those values to '1' or below in 50-22.
