close center door error
  • sharpie
    • Feb 2011
    • 184
    I have a MX4101 with saddlestich finisher. customer had a jam, now the copier says close center door and I cannot find the source or any documentation on this error. Can anyone point me in the right direction?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: close center door error
    I believe that is referring to the passthrough (RBX).
    • faxman28
      • 435
      if it's an fn10 there is door above where the finished booklets come out, it is where the saddle stitch stapler is.
      • sharpie
        • Feb 2011
        • 184
        I have checked both of those areas. The message is actually "close center cover" if that makes a difference with no reference to finisher or anything else for that matter.
        • ntbann
          • Jan 2012
          • 631
          The lift plate on the finisher exit is up. Push it down by hand. Its the one that raises and lowers when paper exits the finisher. Took me a bit to figure that one out as well.
          • MHeon71
            • Oct 2008
            • 489
            Check the sensor on the RBX3 - Section 33 item # 32. It looks like the sensor is PDCS. I believe that is the sensor that gave me the same exact issue. It is tough to see if you are not looking for it.
            • Danwood007
              • Feb 2013
              • 36
              Hi. What was the out come of this? I have exactly the same problem
              • e6i3i
                • May 2020
                • 26
                Thanks. A machine in my office had this problem. Your description helped a lot!
                • ntbann
                  • Jan 2012
                  • 631
                  Your welcome!
