MX-2700 issue
  • DINGO
    • 661
    MX-2700 issue
    Hi friends
    I have a mx 2700 that take a long long time in a wuarm up.
    Any help, thanks in advance.(already try change the fuser unit, not fix)
    regards
  • Jhonjon
    • Sep 2013
    • 208
    Re: MX-2700 issue
    Originally posted by DINGO
    Hi friends
    regards
    What is the value if you calibrate the DV?EE or EL? check if the amount of the Developer and toner is higher than the stirrer. Normally it is the level of the stirrer if the Developer is new...replace it if the amount is way higher than the it.
    • DINGO
      • 661
      Re: MX-2700 issue
      thanks
      • DINGO
        • 661
        Re: MX-2700 issue
        -fix
        -reseat all conetions in the PCU board.
