Load paper on MX2640
  • glimmer1980
    • Aug 2014
    • 105
    Hello,
    We have a MX2640 installed at a client. The machine displays a message load paper, but there is enough paper in the papertray. When he opens and closes the tray the machine prints again.He gets this 3 times a day. We have updated the latest firmware and even changed the DE14 because he sometimes also got the message from the second tray.
    Does anyone know what this could be?
    Kind regards,
    Ramon
  • ntbann
    • Jan 2012
    • 629
    Re: Load paper on MX2640
    Bad Paper lift sensor in the paper feed unit.
    • wyo19
      • Nov 2012
      • 51
      Originally posted by glimmer1980
      Hello,
      Kind regards,
      Ramon
      this is the correct fix replace all the sensors or you shall be going back....MFP-TB-1025_SENSOR REPLACEMENT.PDF
      • lky1978
        • Mar 2009
        • 483
        Hello,
        Kind regards,
        Ramon
        have you "tick" a4/letter auto change over in the setting?
        • Josh93
          • Jul 2014
          • 47
          Fatal mistake forgetting that one haha
          • duane@pbbsinc.com
            • Mar 2011
            • 77
            I also have a mx3640 with exact same issue and the trays get opened and closed to print out and then it goes away.
            I have replaced said sensors with no change and am currently out of options to repair.
            All the settings are set to fit to page and a4/letter resize.
            My problem is over thin clients on a citrix network and both the ud2 driver and pcl6 drivers have been tried.
            All firmware is up to date and ports not being used have been disabled.
            Un fortunately I do not control the network environment and Sharp is not being very cooperative on this matter till I do a package capture on the mfp at hand which is impossible to do cause I do not have and cant get a dumb hub to run the software for the capture.
            Does anyone else experience this LOAD PAPER IN TRAY 1 error on the sharps they service?
            • drowranger
              • Jul 2015
              • 122
              Guys there was a firmware(04.02.G2.a0) released specific for this reason in may 2014. check iF the fw is 04.02.G2.a0 or higher. Current is 05.00.A2.m0 . new fw is definitely helpful.
              • duane@pbbsinc.com
                • Mar 2011
                • 77
                I have the latest ( ARS2_MAIN_0500A2) firmware already loaded and the problem is still happening with load paper two to three times a day and I did confirm that. Do I have to back firmware to the one you listed specific for that problem?
                If anyone has any other suggestions I am all ears.
                The copier was swapped with exact model and options and the new copier is doing it as well.
                I did find a dumb hub and was able to do a packet capture during the failure to no avail Sharp told me to disable another port v1-v3 snmp.
                Still have same issue two to three times a day.
                • duane@pbbsinc.com
                  • Mar 2011
                  • 77
                  hello,
                  we have a mx2640 installed at a client. The machine displays a message load paper, but there is enough paper in the papertray. When he opens and closes the tray the machine prints again.he gets this 3 times a day. We have updated the latest firmware and even changed the de14 because he sometimes also got the message from the second tray.
                  Kind regards,
                  ramon
                  glimmer1980 did some one help you resolve your load paper issue and what was the fix???????
