Sharp MX-3501N
  • tcypy1961
    • 773
    Sharp MX-3501N
    After replacing the black drum cylinder and drum blade, and the yellow drum blade for ghosting/offsetting, I'm now getting called that a light shade of yellow, and a light shade of magenta is on the copies (I'm assuming background, as I've not seen the copies yet). All I did before this problem started was replace the parts listed above. Can this shading issue be resolved by running a simulation? If so, which one? Is it P, interrupt, clear, interrupt to access simulation mode? Thank you for any help given.
  • ZOOTECH
    Senior member of CRS
    • 3378
    Re: Sharp MX-3501N
    A full calibration is necessary after replacing any consumables. No, that is not how to enter simulations - check you PM.
    • harleyrider
      • Oct 2011
      • 348
      Re: Sharp MX-3501N
      Check all supply yields/rotations. Replace as needed. Sometimes they may not reach full yield in low volume machines. As stated then do full calibration.
