MX-6240N Error C1-05
  • Dewald
    • Feb 2015
    • 15
    [Error Code] MX-6240N Error C1-05
    Hi can any one tell me if they know what could be causing this error? I have cleaned the magenta drum unit and the main charge also cleaned the led lights on drum unit.
    I would really appreciate any assistance i can get.
  • harleyrider
    • Oct 2011
    • 348
    Re: MX-6240N Error C1-05
    If you are going to service one of these I would get a manual. There is just to much to them to not have one.
    • Dewald
      • Feb 2015
      • 15
      The Copier has only done about 10k. So its not due for service. Manual says C1-04 is Charger cleaner trouble (Magenta).
      • mojorolla
        The Wolf
        • 2639
        This is a common issuer on the Polaris (6240-7040) and the Herc 2 (904-1204). You can adjust the charge arm but it will come back. We stock the charge unit as this is a constant issue....
        Part # CHLDZ2271DS51
        • Dewald
          • Feb 2015
          • 15
          Problem found. - It was the main charge cleaner motor not turning
