mx623 error f2-68
  • danno
    • Oct 2010
    • 15
    mx623 error f2-68
    fellow tec pulling his hair out.Tried hopper changed, toner full sensor changed, wire harness changed drum/ dev drive unit changed firmware upgraded pcu bd replaced toner cart replaced hopper replaced any help would be appreciated.
  • bilyahn
    • Dec 2006
    • 1467
    Re: mx623 error f2-68
    Maybe I'm looking at the manual wrong but the toner lock sensor (TLS) is located in the transfer belt area according to the diagram on page 4-9 of the SM. You might be looking in the wrong area around the drum. Haven't had this problem so would be interesting to know if that's correct or not.
    Good luck.
    Bil
    • danno
      • Oct 2010
      • 15
      It is waste toner full sensor problem not toner lock sensor thanks. All input appreciated. F2-68.
      • coopers1305
        • Nov 2014
        • 50
        Sensor TNFS
        I'd use sim 10-2 with toner cartage in or sim 30-1 to start. (Manual pgs 6-15 and 6-29)
        You've done everything the manual has said to do and so I'd personally change the PCU PWB as a last resort.
        • danno
          • Oct 2010
          • 15
          Thanks coopers the pcu bd was changed the copier is now back at the shop and the boys are in touch with sharp trying to rectify the problem.
          • danno
            • Oct 2010
            • 15
            Update It was found that the white spring loaded coupling on the hopper was stuck and by some fluke it was stuck on 2 different hoppers therefore fooling us when we switched hoppers.Problem solved.
            • dmary
              • Jun 2017
              • 20
              Good morning,
              sorry to bring up this message in 2023, but it's to thank dwarf for coming back to give his solution.
              This MFP is old and I have one left that is resistant to replacement.
              I got the code F2-68 and naturally ordered cell RDTCT02227FCZZ... for nothing.
              It was the spring that was not powerful enough to push the "pinion" at the front of the hopper which controls the mixing of the used ink from the toner cartridge.
              The pinion was stuck on the axle.
              Fairly simple to repair.
              Thanks again.
              French technician since 1994. Thanks to Google Translator for helping me to make myself understood by you.
