MX 5111 sucking cyan developer
  • ntbann
    • Jan 2012
    • 628
    We have a MX 5111 that has sucked the cyan developer at least 6 time. About every 3 weeks or so. Whats been done. New dv unit, drum unit, both transfer belts, and the HV pwb all to no avail. Any one else seen this or have a suggestion? Thanks in advance.
  • coopers1305
    • Nov 2014
    • 49
    Re: MX 5111 sucking cyan developer
    Change the cyan process unit out. You may be able to rebuild it but that may not fix it permanently.
    • Cookr
      • Dec 2011
      • 184
      You have any luck with this? Dealing with a MX-4100n and its eating up the cyan also replaced C Y M DV's in April. cyan was gone by June replaced again, gone today 7-7-15? I also replace all the drums back when i changed the DV's in April.
      • ntbann
        • Jan 2012
        • 628
        Yes I did. I ended up putting in the updated charge block and springs.
        • Cookr
          • Dec 2011
          • 184
          Happen to have part numbers for what your talking about? because im not sure what you mean. are you talking about the carona unit?
          • ntbann
            • Jan 2012
            • 628
            No not the charge. Diagram 46 item # 12, 13, 14, 15 in the parts guide.
            • mxm
              • Feb 2011
              • 37
              Hi
              we find using mx5140 type dev units solves solve this problem.
              you can use new black dev unit from mx5140 but change the base cover from your cyan unit.
              then set up using sharp calibration procedure (clean optics and I'd sensor before setup)
              • Cookr
                • Dec 2011
                • 184
                Originally posted by mxm
                Hi
                If I try this method do I then use MX-4100n DV or use the MX-5140 DV?
                • mxm
                  • Feb 2011
                  • 37
                  The mx 5111 (5112 in the UK) uses the same dev as the mx 5140.
                  the dev to use is MX-51GVBA
                  also so fit a new drum and MK kit
                  MX-510MK
                  • ntbann
                    • Jan 2012
                    • 628
                    You are just wasting time replacing dv unit. Ive been there. It will do it again. The plastic block has been changed by Sharp due to high voltage bleed through.
                    • Cookr
                      • Dec 2011
                      • 184
                      Yeah I decided to just go ahead and change all that out. Looks like its kinda of a bitch though lol but oh well
                      • ledoux
                        • May 2009
                        • 75
                        We are replacing these tomorrow for the first time for this issue. We looked at machine in the shop to see the best way to replace. Looking like either pull the drive unit and motors off the back or removing the laser shutter rail to get enough room to remove the blocks, which way have you found was the easiest?
                        “Boring damned people. All over the earth. Propagating more boring damned people. What a horror show. The earth swarmed with them.” Buk
                        • paulostmg
                          • Apr 2015
                          • 6
                          We had the same problem. The best way to fix the problem is, you need to buy the developer cover unit, replace drum,MX-510MK and dv bag. The problem is the DV unit is dusting of excessively. The toner dust is going to the main charge unit/grid. Therefore the main sucking up the developer. Sharp has bulletin for toner dusting. I will attach the bulletin with the part number for all color unit.
