AR 168D Keeps saying laod paper but there is paper in the tray
  • drbob101
    • Nov 2014
    • 15
    As the title says. This just started.
    I have turned the machine on and off and treid taking the paper out and reloading, etc.
    ANy ideas?
    Thank you
  • ZOOTECH
    Senior member of CRS
    • 3376
    Re: AR 168D Keeps saying laod paper but there is paper in the tray
    ANy ideas?
    Thank you
    By any chance is it looking for paper in the bypass tray? If not, you may have a broken or bad PED switch lever.
    • drbob101
      • Nov 2014
      • 15
      No, bypass tray is closed.
      I opened the bypass tray thinking I could use it and the same "no paper in tray 1" came up.
      Can you point me to how I would replace/check that PED switch?
      Thankyou
      • drbob101
        • Nov 2014
        • 15
        OK I changed to the bypass tray and it worked.
        How do I troubleshoot that main tray issue?
        Thanks again
        • ZOOTECH
          • 3376
          Thanks again
          Test Command 30-1 will test the paper sensors.
          You can pull the drawer out and visually check if the switch lever is broken.
          If not broken, raise the lever and see if the load paper message goes away.
          Perhaps the trip mechanism that allows the paper tray to raise is not working.
          • drbob101
            • Nov 2014
            • 15
            I am not sure what it is I am looking for under there but if i hold the tray sensor switch and push the copy button the gears turn but the rod with the rubber pads on it that appears to be operated by the gears does not turn.
            Should that rod be affixed to the gear that it is attached to it?
            • harleyrider
              • Oct 2011
              • 348
              Check paper feed solonoid or paper feed clutch. Ar 168's do not have add paper sensors. If they don't feed you get the add paper .
              • drbob101
                • Nov 2014
                • 15
                Ok...
                That gear is turning but the bar with the rubber grippers on it that is on the end of the gear isn't.
                Shouldn't that be turning loading the paper?
                • ZOOTECH
                  • 3376
                  Ok...[ATTACH]28066[/ATTACH]
                  Harleyrider is right, most likely the solenoid is stuck and wont release the clutch which would turn the tires. Much like in a car, the engine is going but until the clutch is released, the wheels aren't turning.
                  • drbob101
                    • Nov 2014
                    • 15
                    Ok. I hear you but did you watch that video? The gear at the end of the shaft that the "tires" are on is turning but the "tire axle" isn't.
                    Id there something behind that gear that I cant see or is it just that the shaft isn't attached to the gear for some reason?
                    • harleyrider
                      • Oct 2011
                      • 348
                      You asked for help. You were given the fix.
                      • ZOOTECH
                        • 3376
                        2) When the COPY button is pressed, the main drive motor starts
                        rotating to drive each drive gear.
                        The pick-up drive gear also is driven at that time. Since, however,
                        the paper feed latch is in contact with the projection of the clutch
                        sleeve, rotation of the drive gear is not transmitted to the pick-up
                        roller, which does not rotate therefore.
                        3) After about 0.1 sec from when the main motor start rotating, the
                        tray paper feed solenoid (PFS) turns on for a moment.
                        This disengages the paper feed latch from the projection of the
                        clutch sleeve, transmitting rotation of the pick-up drive gear to the
                        paper feed roller shaft, rotating the pick-up roller to feed the paper.
                        Hope this helps.
                        • drbob101
                          • Nov 2014
                          • 15
                          Hope this helps.
                          It sure does. Thank you.
                          Now how to test and get at the paper feed soleniod?
                          I have the repair manual. I would appreciate any help in getting started fixing this.
                          • ZOOTECH
                            • 3376
                            Test Command 6-1,-2 will test the paper feed solenoid and resist roller solenoid.
                            To access solenoid, remove the rear cover (I can't remember if something else needs removing too).
                            The solenoid armature will sometimes get a sharp edge which will make it hard to pull away from the clutch
                            gears - sand or file the edge. The solenoid might be OK, but the spring wrapped clutch may have to be replaced.
                            • NeoMatrix
                              Senior Tech.
                              • 3514
                              Check the paper feed clutch solenoid actuator doesn't have a sharp edge. See the attached image.
                              I've seen this on various other models ARM 160/207 etc...
                              Hope That Helps
