Sharp AR BC260 Color Copier 64 bit Driver
  • Tim C
    • 167
    I am looking for a 64 Bit Win 7 Driver for this Sharp AR BC260...Sharp web site is not showing this driver.
    Any help would be greatly appreciated
  • bilyahn
    • Dec 2006
    • 1470
    Re: Sharp AR BC260 Color Copier 64 bit Driver
    Try this one. It's a PCL5 driver for VistaX64 but should work.
    Good luck.
    Bil
    • faxman28
      • 435
      Any printer that does not have driver from manufacturer , you maybe able to get from Microsoft. Go to add printer in win7/win8 , add port, then after the add port screen you should have the screen that shows all your printer manufacturers, there is a button (perform windows update), it can take up to 15 minutes, but it will download all the printer drivers that MS has. when download is complete scroll to sharp and search for your printer. Have used this many times for old printers that Sharp has not made win 7/win 8 drivers. just did the update on my win8.1 dell tablet and the AR BC260 and AR BC320 PCL5c driver appeared.
      • Tim C
        • 167
        Good luck.
        Bil
        [ATTACH]28096[/ATTACH]
        I will try This
        Thank You !
        • Tim C
          • 167
          I will try This
          Thank You !
          • rupesh
            • Oct 2007
            • 36
            Download Center - Sharp
