Sharp mx-311on color
  • antone
    • Oct 2014
    • 344
    Copies black poor print 105k on drum any thing to add to make copy's darker? Maintenance code DC on control panel
  • harleyrider
    • Oct 2011
    • 348
    Re: Sharp mx-311on color
    probably just do maint. and calibrate.
    • antone
      • Oct 2014
      • 344
      What is DC mean?What type of Maintenance
      • ZOOTECH
        Senior member of CRS
        • 3374
        Cyan drum and the other color drums will pop up soon. will need to be replaced and calibrated as mentioned in previous post.
        • antone
          • Oct 2014
          • 344
          Black how many copies their good for and what does DA mean!!!
          • ZOOTECH
            • 3374
            Black drums/dv rated at 100k, color drums/dv rated at 60k; don't see a code for DA, is that a misread?
            Get a manual or call a tech, this is not a job for someone that doesn't know what's going on.
            My apologies, antone; I checked your profile and see you have quite a bit of experience. I did see where Sharp is your most
            hated brand, that might be part of the problem. You will need the service manual, though, and follow the PM schedule.
            If you need additional help, you'll get it.
            • Foxhound
              • Mar 2014
              • 33
              Sharp mx models don't go much past life and you have to go by rotation more than count. Sounds like it just needs a p.m. The codes are as follows except DA havent seen that one.
              TA= Maintenance All
              TC= Maintenance Color
              TK1= Primary Transfer
              TK2= Secondary Transfer
              DK= Drum Black
              DC= Drum Cyan
              DM= Drum Magenta
              DY= Drum Yellow
              VK= Developer Black
              VC,M,Y= Developer Colors
              FK1&2= Upper and Lower Heat roller
              FK3= Web Cleaner
              • antone
                • Oct 2014
                • 344
                Right no DA..MISREAD
