MX5140 LCT
  • mabro1974
    • Feb 2013
    • 39
    MX5140 LCT
    Hi Guys wonder if anyone can help me, i have fitter a lc-11 lct to a mx5140 and when you try to select the tray on screen it just says tray 3 is ready to open...
    I have had this a couple of times in the past but for the life of me i cant remember the cause.
    Thanks in advance
  • ntbann
    • Jan 2012
    • 632
    Re: MX5140 LCT
    Did you update the firmware with the LCC attached?
    • mabro1974
      • Feb 2013
      • 39
      Re: MX5140 LCT
      yeah did that as soon as it was fitted.
      • mttech
        • Mar 2014
        • 127
        Re: MX5140 LCT
        If I remember correctly, this message shows up when the LCC is out of paper. Test your sensors and lift motor with sim 4. Hope this helps.
        • UnitZero
          • Nov 2011
          • 1
          Re: MX5140 LCT
          Check to see if the rear of the LCT is locked in. I ran into this during setup with LCT's. A hard bump along the side of the LCT at the rear frame can knock in place.
