Sharp mx-6240 ld pwb location
  • Btrainfra
    • May 2014
    • 10
    I cannot locate this board or the lsu pwb. The picture of its location in the sevice guide leaves much to be desired. Ive just been unable to locate it. It shows that they're behind the mfp board. Anybody ever have these boards out of the machine?
  • hellcat
    • Jan 2012
    • 132
    Re: Sharp mx-6240 ld pwb location
    ld power board? what exactly are you refering to? Got a part number for it? What problem are you having exactly you need this board?
    I have had to replace a few laser units in this model before but not usually any boards. Are you possibly looking for the laser power board? If so if I am not mistaken it is inside the laser unit.
    • Btrainfra
      • May 2014
      • 10
      I found it. The lsu cntrl pwb is mounted to the actual lsu unit and the LD pwb is inside the unit. Totally not what the service guide shows on the breakdown. Thanks
      • hellcat
        • Jan 2012
        • 132
        yea i kinda figured the one you was looking for was in the lsu itself :P awesome you got it fixed though.
