MX453 w/ FN9
  • mansart
    • 852
    MX453 w/ FN9
    This machine is showing a repeated jam code of FPDD_S
    Only reference I can find to FPDD is Paper Punch collect full. This machine does not have punch unit?????
    What am I missing????
    TIA
  • JTRAV
    • Aug 2014
    • 5
    Re: MX453 w/ FN9
    I am having the same issue. I have updated firmware and replaced the finisher control pwb. This copier does not have a punch unit on it so it is very confusing. After my MXM363 jams it then tells me to remove paper from staple compiler when none is present. I am fortunate enough to have another finisher that I am swapping it out with for in house testing. I will keep you posted with my findings.
    • harleyrider
      • Oct 2011
      • 348
      Re: MX453 w/ FN9
      FPDD_S is bundle exit jam. Check sensors / and wiring for them.
      • faxman28
        • 436
        Re: MX453 w/ FN9
        FPDD_S Bundle exit remaining JAM, Starting the bundle exit operation FSTPD (compiler/bundle area , paper empty sensor) sensor does not turn OFF within the specified time.
        sensor flag (sticking)or sensor could be flaky.
        • mansart
          • 852
          Re: MX453 w/ FN9
          Thanks (to those here, and those "down under").....that was a Sharp acronym brain cramp...appreciate being sent down the correct path.
