Sharp Mx-M7040 Error Code L8-11
  • fbkhan3
    • May 2012
    • 421
    [Error Code] Sharp Mx-M7040 Error Code L8-11
    I'll be visiting tomorrow to have a look at this machine with an error L8-11 and it's strange because i couldn't find this error anywhere in manual all i find is L8-01,02 and 20,does this belong to power controller trouble also and is it okay to swap power controller with another working 7040?
    Thank you very much for all your valuable suggestions.
    Regard's
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: Sharp Mx-M7040 Error Code L8-11
    Do you mean the MX-7040? (aka Polaris) L8-11 is one of the power plugs are unplugged, get the customer to check both plugs are in.
    • fbkhan3
      • May 2012
      • 421
      Thanks a ton Ruben
      yes its Polaris i'll have it checked and report back.
      Kind Regard's
      • fbkhan3
        • May 2012
        • 421
        I just checked with costumers and both plugs are in and it wouldn't reset in simulation mode as well.
        anything else to look in to?
        Regard's
        • fbkhan3
          • May 2012
          • 421
          Thanks Ruben
          I have got it working today it was bad power socket.
          Regard's
          • AAce
            • Jun 2022
            • 14
            I have the same error code, try swapping cables to different socket but same result, does it have something to do with the polaris board? Its a MX-7090
