MX-2640 Fax Default Settings
  • Hansen88
    • 1084
    Hello, we picked up a customer with this 2640. They want the confirmation page to default on always. While this machines menus are similar to most other recent sharps I cant find where the defaults for the fax are. Under image send in settings there are just a couple settings. Just cant find where the main fax default settings are. Thanks for any help.
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: MX-2640 Fax Default Settings
    You will need to login into the web manager to see all of the fax settings.
    Image Send Settings > Fax Settings > Fax Default Settings > Transaction Report Print Select Setting > Broadcasting set to Print All.
    • Hansen88
      • 1084
      ThankYou Ruben. Your info was just what I needed.
