sharp mx-4501 color issues
  • Jim Vitek
    • Mar 2015
    • 5
    Hi, I hope someone can help me with this issue. I dont have a ton of info on this problem due to being very busy and not having alot of time to spend on machine but here goes... first call was for faded color I did a color calibration and it would not calibrate, so I did a drum registration auto adjustment, it also failed. I adjusted the drums manually and got them close enough to complete the auto adjustment but it still wouldnt color calibrate(reason being the magenta was too weak). I ran out of time that day and the next day I took a working magenta dv unit from a known working machine that allowed the color calibration to go thru and copies looked good. About a week later the magenta lost its density and started to fade again, I did not get to go on that call but it sounds like it was the same problems as before. What would cause only the magenta dv to fade like that? a bit of background on machine all 4 mk kits and drums were changed about 8k copies ago. any help would be appreciated
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: sharp mx-4501 color issues
    What are your counters like? An old transfer belt can cause issues where it does not accept the calibration printouts.
    • walterman
      • 196
      Assuming that the mfp's settings are all factory, voltage, density, etc., what are your developer counts? Check firmware, too. I know when they first came out, they had a developing unit issue, that caused the same issue, developing units needed to be replaced because they would not hold their colors ( hopefully these were updated). I would also go through the entire calibration procedure, starting with 44-13 and the density jig, 44-2, etc, and go from there. Also, check and clean all contacts on the transfer belt assemblies.
      • spanky
        • Sep 2012
        • 468
        Putting a used developer unit in would not help you since the 25-2 adjustment would not be the same for the two.
        You must install new developer material in any developer you install and run the 25-2 at that time.
        Have you checked the toner motor and the toner tube that drops the toner into the developer unit?
        Have you run sim 25-1 to see if the toner density sensor in the developer unit is working?
