Sharp MX-6201 rib yellow 94
  • sharphead
    • Aug 2009
    • 285
    A customers MX6201 started jamming PPD2 but I discovered it was on colour only.
    I've cleaned the process control unit and recalibrated with the jig, I've cleaned the drum phase sensors. I've swapped the primary transfer unit, yellow drum and developer units but I am still getting the same problem. When a run 50-22 I get yellow rib error. When I try a sky copy it is laying the full yellow image onto the primary transfer belt.
    Any ideas.
  • sharphead
    • Aug 2009
    • 285
    Re: Sharp MX-6201 rib yellow 94
    I should have said the primary transfer belt is dropping down fine.
    • ntbann
      • Jan 2012
      • 626
      Replace the color drum phase sensor.
      • ntbann
        • Jan 2012
        • 626
        If you look in 22-4 you will probably see an error code.
        • sharphead
          • Aug 2009
          • 285
          Thanks replaced the yellow sensor. Getting copies out but all the colours fade on the front edge
