Sharp MX 2700N white streak in black
  • rightbrained
    • Oct 2014
    • 40
    I am having an issue with a white streak running through the black on my Sharp MX 2700N.
    The attached photo shows a test print printed in portrait and landscape mode.
    In addition to wiping all the rollers and belts and cleaning everything, I have replaced the green roller in the black drum. I also tried switching the black drum with the magenta drum and the streak still printed in the black. So I think that eliminates the drum.
    So, that leaves the black developer unit? Are there replaceable parts on the developer unit? Can it be rebuilt or is it only available as a whole unit. Or, I am off base completely?
  • ZOOTECH
    Senior member of CRS
    • 3378
    Re: Sharp MX 2700N white streak in black
    Originally posted by rightbrained
    [ATTACH=CONFIG]28772[/ATTACH]
    You may have contamination in the black developer unit - easy to check, just pull it out and check the 'brush'; you could also have a dirty LSU slit glass.
    • rightbrained
      • Oct 2014
      • 40
      Fixed...Dirty LSU slit glass. I can't believe how simple that was. Apparently I've been inserting the cleaning wand upside down. When I pulled the drum and developer unit, I could see that the wand went in face down.
      Any idea where I can order some fresh pads for the cleaning wand for the LSU glass? Or the part number? Mine is pretty black now.
      • ZOOTECH
        • 3378
        Check the waste toner bottle, it should have a couple.
        • harleyrider
          • Oct 2011
          • 348
          The # for the pad is CDAIU0699DS71. They do come with the waste bottle.
          • benalvarez
            • Feb 2015
            • 27
            if you are in a pinch, I don't know what type of white wiping cloths you have to use, but the ones our company supplies to us tears down the length. You can wrap a thin strip around the wand and use it.
