MX5111 not fusing across entire page.
  • harps05
    Field Service Engineer
    • Mar 2012
    • 112
    Client has a MX5111 which has just recently had the fuser rebuilt due to damn fuser belt "meandering" problem.
    It was working fine for nearly a month until today. When it prints a page, the image is not fusing along the entire page.
    The problem areas are about an inch wide and half an inch in from each edge. It is printing A4 standard orientation (not A4R).
    I will be returning tomorrow but as I don't have a spare machine to test parts, or any heat lamps etc. I thought I would just see if anyone else has encountered this type of problem.
    Thanks Guys.
  • skookumchuck
    • Feb 2012
    • 62
    Re: MX5111 not fusing across entire page.
    I had a similar problem. I think there is a bulletin for that adjusting temperatures. It didn't seem to make any difference and then after I reset the temp's everything seemed to start working OK
    • ntbann
      • Jan 2012
      • 628
      Set the machine to 23 to 28lbs paper setting under device control.
      • Hansen88
        • 1066
        I had the pressure spring on one side break one time causing that type problem.
        • copytechonline
          • Nov 2011
          • 40
          As above check pressure springs, they break and can cause this.
          • albionjames
            • May 2015
            • 3
            a bit of a late reply to old thread but I have had one of the thermostats pop on the fusing belt unit cause this. It doesn't throw up an error code either. resetting the thermostat normally works but it may have to be replaced if necessary
