MX-3640 printing issue
  • Madnhain
    • Dec 2012
    • 148
    [Misc] MX-3640 printing issue
    So, a customer emailed me a page with this statement: ""
    See attached.
    Sharp_Printer_Sharp@chaznline.com_20150417_115431.pdf
    It is a 3 hour drive to the customer location and I've never heard of this and can't find anything in the Sharp manuals. A quick prayer to St. Google (the patron saint of all things unknown) leads me to believe that it's some sort of PostScript issue.
    This is a 3 month old MX-3640.
    I'm leaning towards PWB... Has anyone seen this before?
    Thanks in advance!
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2596
    Re: MX-3640 printing issue
    Definitely a postscript issue. I would start with memory before jumping to boards.
    • Madnhain
      • Dec 2012
      • 148
      There was mention of this in a TB, but it had to do with printing excel documents from Mac OS. Suggested a FW update.... could be related I suppose. I'll try the FM, do some memory tests and go from there... Thanks!
      • mansart
        • 852
        If PDF try "Print as Image"
        3 hour drive.....I would first ask customer to allow you to remote in via Show My PC or something similar and do firmware remotely.
        • faxman28
          • 436
          Offending command addglyph points to a problem with a specific text or font element.
          Is it the same doc or same type of doc (same program to create doc ,like adobe , quark ) try the same job using PCL instead of Postscript.
          forget the pcl missed that you mentioned Mac OS . Make sure the Mac "driver" was setup with LPD and not on Bonjur or port 9100. Mac printing seems to do better with LPD on the Sharp MFPs.
          • Madnhain
            • Dec 2012
            • 148
            thank you all. I will let you know how it turns out!
