Sharp mx 2314 - scan network destination adress update
  • osue07
    • Jul 2025
    Hi am trying to update the network address which my scans go to
    when I put the address in it doesn't remember it and I have to put the
    new address in every time I want to scan
    Any help appreciated
    Kind regards
    Mark
  • swagreis
    • Jun 2008
    • 92
    Re: Sharp mx 2314 - scan network destination adress update
    U mean IP of computers that scans going to
    If yes give static IP's to computers
    • osue07
      No the ip address is static, when I put the new scan location in, the photocopier does
      not remember the address and sends the scan to the old address.
      basically if I add a new address for a scan to go to. It does not store it in the address book
      Think it may be an administrative setting possibly
      Many thanks
      mark
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        When you create the scan address, make sure you tick "Set As Default Used", otherwise you will need to select the address every time you want to scan.
        It is best to add the addresses from the web manager and not the machine, as this checkbox is easy to miss.
        A random google shows: How To Add An Email Address Into The Address Book of your Sharp Copier (ignore the email part, it applies to all types of addresses)
