Intermitence jam on MX-M753
  • Stephanemi
    • Jul 2025
    [Jamming] Intermitence jam on MX-M753
  • Tom54
    • Feb 2013
    • 8
    Re: Intermitence jam on MX-M753
    One-way gear in fuser drive assembly slips.
    • Stephanemi
      The gears on the machine seem ok
      The fuser has already been changed
      • Tom54
        • Feb 2013
        • 8
        The gear is on the machine side and if you remove the drive assy and turn the one-way gear you will feel it slip thus loosing your drive to the fuser.
        • siavashsaqi
          • May 2015
          • 11
          i had that problem in mx-3501 & i found the very small laceration (rupture) on the transfer belt.i don't know what is relevance between laceration belt & transport paper!cause it was rolling well.but when i replace that it was solved!
          i hope for you not torned the belt.cause transfer belt is so expensive in my country and maybe be costly in france too.
          • gbfan
            • Aug 2010
            • 19
            I agree with Tom54 - I have had the one-way go out on three separate machines causing this jam (just as it gets into the nip of the fuser roller) replace the one-way or the whole fusing drive section and you will be good to go...
            • sharpie
              • Feb 2011
              • 182
              I have had the drive gear that meshes with the upper roller gear wear out to the point that there is intermittent or no drive to the fuser. If you have already changed the fuser then that rules out the fuser upper roller gear which also seem to be a weak point on this unit.
              • faxman28
                • 435
                There is a bulletin in U.S. for POD1 jams and to perform the following:
                Replace the fusing drive unit (CFRM-1103DS54). Or replace the one-way gear NGERH1581FCZ1 and the fusing
                joint shaft NSFTZ3263FCZ1.
