MX-2301N DEAD
  • Polo-022
    • Sep 2007
    • 484
    MX-2301N DEAD
    Hello,
    i have a customer with a dead MX-2301N. (No display ,no initialization)
    Measuring at low voltage power supply outputs, i read only 4.7 V. No other voltages at all! Leds on controller PWB are lit.( 5 or 6 in vertical sequence)
    I do not have a service manual for this product.
    Should i have to remove power supply for further check... or it might be something else??
    Thanks in advance for any input!
  • ivan123
    • Oct 2014
    • 54
    Re: MX-2301N DEAD
    Check memory's or sd card if machine has it.
    • benalvarez
      • Feb 2015
      • 27
      Re: MX-2301N DEAD
      Might sound like a dumb question, but is the outlet live? What are the Vrms volts? Have you started with the simplest of troubleshooting to determine if the outlet could be defective? It has happened many times to me that the customer says the mfp is dead, but it's really the outlet that's dead.
      • Alpanapa
        • 20
        Re: MX-2301N DEAD
        maybe this will help
        • ZOOTECH
          Senior member of CRS
          • 3375
          Re: MX-2301N DEAD
          [ATTACH=CONFIG]29352[/ATTACH]
          What manual and section did you find this info? I could have used this last year when I had the same no boot problem.
          • Alpanapa
            • 20
            Re: MX-2301N DEAD
            Any service manual, chapter Troubleshooting, after the "Details of error codes and countermeasures". Just do a search on "led display" and you will find it, there is couple of pages with hints when mfp won't boot.
            • ZOOTECH
              • 3375
              Re: MX-2301N DEAD
              I don't have a chapter called "Troubleshooting" in any manual I looked at, and the search came up empty for this type of chart. Maybe the European manuals are different (?).
              Anyway, I hope this chart is universal to the different families of Sharps - thanks again.
              • Alpanapa
                • 20
                Re: MX-2301N DEAD
                I took it from:
                SERVICE MANUAL
                CODE: 00ZMX3610/S5E
                MODEL
                MX-1810U/2010U
                MX-2310U/3111U
                MX-2610N/3110N
                MX-3610N
                Chapter [6] Troubleshooting (The section where all the Error code is descibed (like Detail, Cause and Check & Remedy)) Last 2 pages of that chapter is info and hints about mfp not booting
                Page 355 (of 764)
                • ZOOTECH
                  • 3375
                  Re: MX-2301N DEAD
                  I took it from:
                  SERVICE MANUAL
                  CODE: 00ZMX3610/S5E
                  MODEL
                  MX-1810U/2010U
                  MX-2310U/3111U
                  MX-2610N/3110N
                  MX-3610N
                  Page 355 (of 764)
                  Thanks, Christian, that is the first time, that I remember, seeing an actual Troubleshooting chapter.
                  • Polo-022
                    • Sep 2007
                    • 484
                    Re: MX-2301N DEAD
                    Thanks a lot for your reply Alpanapa but what does it mean in Sharp language : Reus Asic trouble ??
                    (I have all Leds on)
                    • walt
                      • May 2015
                      • 15
                      Re: MX-2301N DEAD
                      There is a small board which the memory board is connected to, it has about three fuses. One of it is likely broken, if it is, then replace it. I had such an issue but it was for ARM. It may work for u too. Goodluck
                      • Alpanapa
                        • 20
                        Re: MX-2301N DEAD
                        ASIC: Application Specific Integrated Circuit
                        Check the MFP control PWB, you will find something like this:
                        Buffalo_IFC-ILP4_VIA_VT6306.jpg This is an ASIC.
                        I had one customer with that problem, i found out that it was something wrong with the power on the machine (The whole MFP was leaking 130 Volt, it was a fun thing to find out )
                        After fixing the volt leaking problem, i also had all lights on the MFP PWB, with the Reus Asic Trouble, so i changed the hole MFP PWB card and it has been working for over 1 year now.
                        • Polo-022
                          • Sep 2007
                          • 484
                          Re: MX-2301N DEAD
                          I decided to remove the low voltage power supply first , to verify
                          if it has a real problem.
                          It seems that it is not an easy repair procedure , because i don't have the information how to remove it from the machine!!
                          By the way i will check everything else has been suggested here..
                          I'll be back!
