Sharp AR 5420
  • copyalbania
    • Aug 2009
    • 165
    Sharp AR 5420
    Hello everyone?
    I am trying to install as a usb scanner driver for Sharp AR5420in windows xp computer but i have searched in Sharp website with no luck of the driver.
    Also i do not have the original cd of the driver?
    Does anyone have a clue where i can find scanner driver ( twain ) driver ?
    Please help ..
  • ivan123
    • Oct 2014
    • 54
    Re: Sharp AR 5420
    You can not find driver because this machine is only copier.
    • copyalbania
      • Aug 2009
      • 165
      Re: Sharp AR 5420
      The copier has a USB connection and i have connected to the computer and it prints fine..
      • ivan123
        • Oct 2014
        • 54
        Re: Sharp AR 5420
        So you probably don't have original pwb in machine. Check on sharp-cee website - it is only copier. If you can print you can try with drivers for AR203 -that's similar /same machine (if I have good memory &#128515
        • ivan123
          • Oct 2014
          • 54
          Re: Sharp AR 5420
          • copyalbania
            • Aug 2009
            • 165
            Re: Sharp AR 5420
            Hello
            Thanks Ivan i have checked in Sharp website and also i have installed ar203 drivers and the machine works fine as a printer but i need as a scanner.
            I though that the machine works ok as a printer why not as a scanner that is why i posted this thread....
            • DavePo
              • Jul 2008
              • 305
              Re: Sharp AR 5420
              Reading the Brochure it states that only the AR203E is capable of scanning. The AR5420 was copy only. If it has a AR203 PWB to allow usb connection. Does also have the operation pwb. to give you scan button? All things considered it shouldn't scan as it was not intended to scan.
              • copyalbania
                • Aug 2009
                • 165
                Re: Sharp AR 5420
                Hello DavePo ,
                Thanks for the reply.
                I see only the USB connection....what is the operation pwb ? do you have a photo or where is located?
                • ivan123
                  • Oct 2014
                  • 54
                  Re: Sharp AR 5420
                  He means on keyboard
