Sharp mx 4500 improper cartridge
+ More Options
Posts
  • walt
    • May 2015
    • 15
    [Error Code] Sharp mx 4500 improper cartridge
    My sharp MX 4500 is showing improper cartridge after its memory was cleared, but the sensor is the correct one for it. A million thanks to who could help me with this challenge.
  • Jhonjon
    • Sep 2013
    • 208
    Re: Sharp mx 4500 improper cartridge
    Try to check the destination setting...
    • thomfish
      • Jul 2014
      • 101
      I guess you have refilled cartridge and chip is broken. I had that issue before. You will need to change chip reset for this cartridge. My cartridge does not even work with other machines. I changed chip and it works fine.
      If there is any other way to fix this problem I also would like to hear the solution from experienced engineers.
