sharp mx-m550n light copies on back side when using adf
  • dcooper
    • Nov 2014
    • 37
    [Misc] sharp mx-m550n light copies on back side when using adf
    I was wondering if someone could help me out. When using adf I get light copies only on back side, the front side is ok.
    I haven't had to do anything with the CIS unit before so I was wondering if you can clean it or do you have to replace it.
    If you have to replace it , are there any adjustments you have to do? Thanks for your your help!
  • sharpie
    • Feb 2011
    • 174
    Re: sharp mx-m550n light copies on back side when using adf
    If you scan duplex from glass are the 2nd side OK there?
